18" x 8" Too Wide??
By the way, when yu say the stretched tires affect the handling slightly...I plan to do a few track days and such, so handling is important, Should I thus get 225 or something wider? Any dangers of pushing the stretched tire hard in cornering? Would it give out under pressure?
the offset is 48mm & i haven't had any issues at all. not one rub or anything. i havent felt any difference in handling, but then again im not pushing the limits either (thats what i have my Gixxer for!). i doubt im going to lower it, but i think im going to get slightly larger tires. i want that squared off look again
yeah, it would mess with the speedo unless you got it reprogrammed.
For a 235 you would want a 40 series at the most if not a 35. Check tire diameter vs stock.
