Road///Race - 08 Megan Coilovers
That's right, after a long long wait, we finally have the new 2008 Lancer Megan Racing coilovers available.
THEY ARE $869 AND WE HAVE THEM IN STOCK NOW
these will be on the website 2 morro.
Rock, will you be having a readily available supply for this???? looks like i need to save up to get a set of these
I might bypass the whole drop springs and just save a little more to get a set of these bad boys
kimchi....i'm pretty sure that's what it is....i never had coilovers in any of my cars
but if i'm correct, they replace your stock struts ?????
800 bucks is a good price for coil overs.....granted it's a good quality coil over, but 800 bucks is 800 bucks..........i dont know about you guys but i dont have 800 bucks lying around to just buy these outright.........wish i did, but lowpaying job + fulltime student = less money for dick morgan
gotta save up for a while for these bad boys
1. Remove the bottom two strut bolts.
2. Remove the brake hoses and speed sensor.
3. Remove the top three nuts.
4. Swap stock for coilover.
5. Put all nuts/bolts back on.
6. Set ride height, set dampening.
7. Put wheels back on, get alignment, enjoy.
All of which is easy and explained in the Megan instructions, no doubt.
Less than 5 minutes for each side to adjust. You'll need 3 things to adjust the height: floor jack, spanner wrench (should come with the kit coilover kit), and a measuring tape. Jack up the vehicle, loosen the lock nut, turn the strut's shaft to the desired length, measure the shafts new length, tighten the lock nut and drop the vehicle. Once your done with all 4, measure the highest point of the fenderwell to the center of the axle.
Now the question is, how many adjusting points does it have for dampening?
^ here's a link for all you need to know and even more to confuse you about suspension;
http://en.wikipedia.org/wiki/Suspension_%28vehicle%29
- Designed for the 2008 Mitsubishi Lancer ES, DE & GTS
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
32 Levels of Adjustment:
1-8: Suggested for track use. 9-16: Suggested for mountain/aggressive use. 17-32: Suggested for common street use.
Currently the only mod i'm considering. Until I can afford the turbo kit.
- Aluminum Brackets
