anyone have pictures of 15x6.5 4x100+40mm offset
im looking at getting some ROTA Wheels Subzero 15x6.5 (4x100+40mm, Hub 67.1) from http://www.racinglab.com/rowhs1.html , and i read thru the truth your need to hear about the lower half of your car stickie... kensuke states in there that his opinion is to run a Spoon SW388 Rims in either 16x7 (+35 or +45 offset) or 15x6.5 (+45 offset) 15" is 8.36lbs, 16" is 11.88lbs.
my question is does anyone have pictures of a lancer with either of these rims or one with a 40mm offset so i can see how well it lines up with the fender, i want them to be a little on the inside not the outside...
will i need to get a 5mm space all around to get them to clear anything, the plan is to run these with stock oz lancer size tires 195/60-15 . i dont like thin rubber look, thats why i dont want to get much bigger in rim size...
also i was reading the offset guide, is a 15x6.5 with a 40mm offset and a 17x8 with a 40mm offset will those rims line up exactly the same on the offset point of view with the side of the car only difference is how tall they are... will all clearances be the same? sorry if im not being clear here i dont know how else to ask this question.
urbanknight
41
Jan 11, 2014 02:58 PM
FL_SilverEvo8
Oct 4, 2013 10:25 PM
