Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Rotor removal same on 03 es?
Old Apr 30, 2008 | 05:46 PM
wrightty82's Avatar
I'm going to change my front pads and rotors for the first time...I've searched rotor removal and found in the evo forums that you can remove the front rotors by hitting them with a rubber mallet or using two bolts to work the rotor off.
So my question is do the 03 es rotors remove the same way?
Old Apr 30, 2008 | 05:56 PM
03_Lancer_ES's Avatar
I think that's a pretty common technique for removing them, yeh.
Old Apr 30, 2008 | 06:03 PM
wrightty82's Avatar
cheers
thanks!
Old Apr 30, 2008 | 07:14 PM
darkmitsu's Avatar
yeah sometimes the rotor gets rusted to the hub, a rubber mallet is the trick... bang shimmy shimmy bang shimmy shimmy...
Old Jun 9, 2008 | 06:36 AM
Thundurbyrd's Avatar
A helpful hint is to put a little grease on the back of the rotor where it mounts to the hub. This will help out the next time you change your brakes so you don't have to keep swinging the hammer.
Old Jun 9, 2008 | 08:13 AM
oakley198877's Avatar
make sure when you put the new pads on, you apply some pad grease(or what ever it's called) on the side that contacts with the clips too~
Old Jun 11, 2008 | 12:22 PM
^ Yes, or else you'll get noise from your pads sliding around in the calipers.
stunt2
20
Oct 26, 2014 07:19 PM
OZ_kidd
Lancer How Tos / Installations
Jul 10, 2013 10:28 AM
ishotphish
Mar 31, 2013 01:12 PM
ambystom01
11
Feb 3, 2005 04:38 PM
Quick Reply: Rotor removal same on 03 es?
