AM wheel problems??
AM wheel problems??
Hey guys,
I just ordered new wheels and tires from discounttiredirect.com, and when I chose the wheels it said 2008 Mitsubishi Lancer GTS 18" TPMS. Now when you guys installed your wheels, was there any problems, or did you have to go to the dealer and have them reset something?
Thanks
Thanks
no, the sensors will recognize themselves. It doesn't matter if you put them on diffferent wheels either. The sensor valve stem will flex from the sensor part to fit different wheels. (i hope you understand what I mean. Will you be doing it yourself?? if so them just be careful removing and installing the tires. If not then you don't have much to worry about, people are trained to do this.
Also I recommend you get sensor seal kits (o-rings, nuts, valve cores) This reduces the chance of it leaking.
