GSR Mags on Lancer GT 2009
I will get my new Lancer GT 2009 (comes with 16" Mags) Thursday and I was wondering if the Mags of an EVO GSR would fit?
I know someone willing to change his GSR Mags, so I was wondering if I can install that on my Lancer?
Thanks
Thanks
but you'd need the perfect offset or its gonna rub at 8.5 wide. Adjustable camber would let you run wider though easily enough i think. But as was mentioned.... if you know the guy why not just see if you can test fit them.
Use this page, its very useful to compare sizes and offsets so you can see if that fits on your car.. http://www.bigcustomwheels.com/rt_specs.jsp
Here's an example of the page I mentioned early.. ^^^^ Hope it helps.. Edit** Don't know how to put this info organized(the forum dont let me) sorry.
Mitsubishi Lancer GTS 08-09
Stock Aftermarket Example
Wheels: Wheel 1 Wheel 2
Wheel size 18x7 ET 46 18x8.5 ET 33(Offset)
BackSpace 147 mm (5.8'') 153 mm (6'')
6 mm (0.2'') deeper.Rim Lip 32 mm (1.3'') wider
Tires: Tire 1 Tire 2
Tire size 215/45-18 235/40-18
Section width 215 mm (8.5'') 235 mm (9.3'')
Sidewall 97 mm (3.8'') 94 mm (3.7'')
Tire diameter 651 mm (25.6'') 645 mm (25.4'')
6 mm (0.9%) shorter.
Rim sizes 18x6 to 18x8 18x7 to 18x9
Circumference 2044 mm (80.5'') 2025 mm (79.7'')
Revs per mile 787.3 794.6
Speedometer Assuming that this
is OEM tire and
speedometer
readings are correct: When speedometer reads 60mph (96.6km/h) actual speed will be 59.4mph (95.6km/h): 1% slower.
Clearance: Package 1 Package 2
Suspension Assuming that this is 100% clear
OEM wheel/tire and there (leaves even more room than OEM)
is no any problems with
clearance on both sides.
Wheelwells stock 100% clear
Fenders stock Package will stick out 23 mm (0.9'')farther.
Make sure that you have enough room under
the fender. If not, consider narrower tires
or higher offset.
is OEM tire and
speedometer
or higher offset.
Last edited by Turbotech; Aug 26, 2008 at 08:44 PM. Reason: Don't know how to put this info organized(the forum dont let me) sorry.
OsoiCT9A
For Sale - Miscellaneous Automotive
Jan 2, 2008 09:03 PM
