hubs
hubs
i say a thread a week ago but i cant seem to find it. 03 lancer oz. front disk rear drum. is there another lancer that i can swap hubs or a setup where i can run rear disks too? im not sure if the ralliart has rear disks but something like that.
well the ralliart has disc brakes all around, but it also has a bolt pattern of 5 x 114.3 so unless you want 4 lugs in the front and 5 lugs in the back then you will have to swap the fronts as well
Yeah, you need ralliart hubs. If you get the backing plate, rotors, pads, calipers and e brake with cable, you can add rear disk brakes on the rear. The plates are only like 50 a piece on mitsubishiparts.net. You might, might be able to use the 2g eclipse rear disk brake swap, but you'll need ralliart spindles.
