Removing rear hub?
17x7 +42 -16..
recently i found a local Italian Sparco Distributor.. so i bought some Sparco 16mm hub centric spacers.. so my current setup is 17x7 +42..
the fronts are on.. but i cant fit the extended lug nuts in the rear.. i already have an idea.. but whats the easiest way to remove the rear hubs?.. my car is on jack stands in the driveway.. thanks..
here are some pics..
use a screw driver or hubcap removal tool to get the tin cap off, the undo the cotter pin or whatever is locking the hub nut, remove the bearing and pull the hub off.
This is also a good time to grease the bearing and check their condition. Also check the grease seal. Do find the specs for tightening the bearing nut back up or you could have a failure. Usually you just tighten the nut by hand until no more play is felt then lock it.
pry the little silver cap off with a flat head screw driver and a hammer like what camshaft said and pull the hand brake up and loosen the bolt everything should be pretty straight forward from there let us know how it goes
just got that cap off.. but dont have the socket for it.. i just put it all back together and im going to the base hobby shop.. free lift and air tools.. what do i do if the spindle spins when im tryin to loosen the bolt..
by the way.. taking off the hubs was the easiest part.. for some reason the bolts that hold the in place didnt have the safety pin through them like any other car would have.. i took an air gun to the bolt on the softest setting and it can right off.. and the hub just followed.. i wonder what the specs for hubs and spindles are.. we could probably swap the hubs out with other cars to get what ever lug pattern we want.. i wish i had a local junk yard to experiment!.. 5 lug pattern any1..
IMO with a 5 lug pattern in the rear just drill the pattern out on the drum and slide it on.. and the same for the rotors in the front.. that way we could still use our stock brake assembly..
The rear hub is an integral hub/bearing assembly. It doesn't have adjustable bearings like a conventional hub. That big nut is simply tightened down until it stops, and the preload is built into the hub assembly. Definitely don't leave it hand tight! Also I've never had much luck reusing them after they've been pulled off that spindle stub. They seem to come apart. New ones are cheap enough though so I wouldn't worry about it.
so i called the local sparco shop where i got the spacers.. and after struggling with italian, spanish, and english.. the guy said they had extra lugs there.. to bring 1 of mine.. but i dont know how to get there so i have to wait for my buddy with the prelude to take me back out there.. ill try to take pics of the shop next time..
CadiLuva
For Sale - Wheels / Tires
Oct 17, 2010 07:17 PM
