Broke lug nut screws while trying to remove wheel
Hello Guys,
I broke two of my lug nut screws whilst trying to unscrew my lug nuts today. (front passenger)
Do I have to replace the whole hub now?
Is there any easy way to change the screws? Any how to's on how to do this?
Thanks!
Dbansal
Thanks!
Dbansal
My Thread
check out the link and the pics.. all you need are the new studs, a hammer, and the sockets to take the caliper off..
first remove the wheel.. then remove the caliper.. then remove the rotor.. which should leave you with the hub exposed.. then literally hammer the broken studs once or twice dead center.. they will pop right off.. VERY IMPORTANT.. the new studs should not wiggle around in the hub.. make sure they are seated correctly by using spacers and tightening them into place before adding the wheel..
Gtizks
11
Jan 5, 2017 08:11 PM
