Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
tires: 205 or 215
Old Mar 3, 2009 | 11:14 AM
WangMan's Avatar
tires: 205 or 215
I've got some new 17x7.5 Rotas that I'm putting on my car soon as it warms up. A lot of people recommend 215 size tires for 7.5 inch wide rims but I like the stretched look of 205. I wanna run 205/45 17 size tires on these rims. Just wanna make sure nobody thinks that would be a problem
Also, I figured with tires a bit less wide, I'd have less to worry about in terms of rubbing
Any input? Thanks in advance guys
Old Mar 3, 2009 | 11:30 AM
ambystom01's Avatar
215s will be a bit of a stretch.
Old Mar 3, 2009 | 12:03 PM
WangMan's Avatar
I ran 215s on a set of 7 inch wide wheels and the sidewall was straight up, didn't look too good imo. Will the extra half inch make a noticeable difference?
Old Mar 3, 2009 | 12:11 PM
ambystom01's Avatar
Depends on the tire but it should.
Old Mar 3, 2009 | 12:40 PM
ThunderOZ's Avatar
I feel like 205s are stretched on my 17x7 rims now...
Old Mar 3, 2009 | 05:29 PM
Boostedlancer$'s Avatar
i ran 215/45R17 and they rubbed when i lowered my car i like the 215's but they have to be a 40 series so they dont rub.
Old Mar 3, 2009 | 05:43 PM
Juan Martinez's Avatar
Read this article, https://www.evolutionm.net/forums/la...set-guide.html
I think he ran 205/45 on them. As long as you have the proper offset, you should be able to run 215/40 ot 45 if its not lowered or still at stock height. I wanted to try 225 on mine, but doubt it will work. I'm going with 215 myself and I have seen them, but you do need the right offset.
Old Mar 4, 2009 | 01:30 AM
WangMan's Avatar
Well my car is lowered, do I have much of a chance of fitting 215's in there? When I tried the wheel on the offset worked pretty damn well with a 5mm spacer: the outside was flush with the fender and the inside was a finger or so away from the suspension... but as well as it sits I'd hate nothing more than to rub. I sold my old 7" wide wheels with 215/45's to someone and he rubbed with his stock suspension
Still haven't decided, any more input is greatly appreciated
edit: and I'm set on 45 sidewall because I'm afraid to drive on the roads here with anything smaller
Old Mar 4, 2009 | 10:04 PM
What offset where you old rims and what car did your friend put them on?
did you try your old 215 tires?
Old Mar 4, 2009 | 11:51 PM
link62's Avatar
i bought his old rims and they would rub the inside of the inner wall everytime i would turn the wheel all the way to make a u both right and left and i have a 03 es and i belive it was 215/45/17
Old Mar 5, 2009 | 12:18 AM
link62's Avatar
This is the area on both sides that would rub
Old Mar 5, 2009 | 01:18 AM
WangMan's Avatar
Juan, I think the rims I sold to Link were a 38 offset. These rims I just bought are a 45mm offset plus a 5mm spacer which brings it to about 40.
Old Mar 5, 2009 | 08:07 AM
215 work awesome i have them. i had the right offset but couldnt run that tall of a tire so i had to go down to a 215/40R17 doesnt even come close to rubbing anymore.
cyanide
Sep 26, 2009 05:44 AM
MSFIT
Jan 3, 2007 12:46 PM
TheDriver11421
12
Apr 26, 2004 09:19 AM
HobieKopek
21
Jul 23, 2003 05:51 PM
i_love_spool
Jul 2, 2003 05:42 AM
Quick Reply: tires: 205 or 215
