Konig Countersteer R 16x7 25mm offset
would this fit on the 08 lancer es. i found them cheap and really like them. but i don't know to much about rims. and i see the offset is 25mm and a 83.2mm hub bore and don't know if they will fit without any problems. they r titanium bronze! thanks.
well since its only 16x7 i doubt the +25 would be toooo far.. but it still seems like its a posibility it might not.. so either test fit them or look for something with a higher offset
If your riding stock height, you should be completely fine. Someone ran 18x8.5 +30 with 245/40/18 tires on stock height. They don't rub but hard U turns they rub though. With 16x7 +25 should be fine. It definitly wouldn't even be sticking out pass the fenders. It will stick out farther than the stock wheels though by an inch or an inch half.
XRS-Lift
Oct 8, 2003 11:30 PM
16, 16x7, 25, 25mm, countersteer, countersteerr, countersteers, konig, konigs, lancer, offset, rated, remember, remembers, wheel
