Help with replacing rear hub
My car started making a whirring sound lately and it seems to be getting louder. I've taken the rear wheels off and narrowed the problem down to a bad rear bearing (which i'll have to replace the hub.)
I've never replaced a hub before and need some pointers. My plan was to:
1. remove hub cap
2. remove self-locking nut 30mm nut
3. remove drum
4. ???hammer??? rear hub out??? i'm not really sure how i'd go about removing that?
how would I install the new hub after i got the old one out? also does a new hub come with studs?
1. remove hub cap
3. remove drum
Trust me, it's confirmed. Just make sure you clean off the axle surface VERY well before putting the new hub on so there is no dirt or contamination to scar the bearing when installing. And be sure to torque the axle nut down to spec and not just tighten it down with an impact gun.
BoostIt
Jan 25, 2016 07:21 PM
Juan Martinez
Jan 21, 2008 03:37 PM
crypto
12
Jan 22, 2007 02:16 PM
vtluu
Jul 24, 2005 08:33 PM
