Is a rear sway bar necessary if you have coilovers?
I'm just sick of having to lube up the bushings every few weeks and am wondering if I lose any handling if I just take it off even though I have coil overs.
Thanks
Thanks
Instead of grease under the bushings wrap the bar in white teflon plumbers tape. I had the same problem and now no more squeaking! It works I promise. Don't be stingy when you wrap it.
EVORaab
May 21, 2007 11:13 PM
bar, bars, coil, coilover, coilovers, evolutionm, lubricating, necessary, needed, overs, rear, sway, swaybars, unecessary, work
