Rota DPT 18x8.5 for the 2008+ Lancer *NEW SHOES INSIDE*
We're back again helping out the 08+ Lancer community achieve the perfect set-up. We just recently received our new shipment of the DPT 18x8.5 +44 made specifically for all you 08+ Lancer owners. These wheel are extremely light, weighing in at only 19.3lbs and will offer an awesome near flush fit. You can easily fit 235/40/18 tires with no modifications and it will also perform great!
-Tommy
A new shipment of DPT just arrived and they are now in stock and ready to ship Available colors are listed below
Flat Black
Hyper Silver
Introducing the NEW Gold
Installed Pictures (COMING SOON)
Flat Black
Hyper Silver
-Tommy
The Torque is offered in 18x8 +48 fitment for the Lancer. We also recently released the Grid in 18x8.5 +44 fitment specifically for the 08+ Lancer. I made an announcement thread with pictures here
https://www.evolutionm.net/forums/la...r-concave.html
We've done various test fitting on the 2008+ Lancer and have found that 18x8.5 +44 is an ideal fitment for this model. This setup isn't meant as a "flush" setup and will be a direct bolt on fit that will not require fender modifications. This setup is meant for someone who wants an install it and forget it setup that will look amazing and perform well on the street/track.
We do offer Rota DPT's in an aggressive 18x9.5 +35 for those looking for a flush setup
The 08+ Lancer runs a much higher offset wheel than the 08/09 Evo. This model was designed around a high offset application and allows for a nice sized lip and proper caliper clearance. As mentioned above, we offer a wider model with concave in 18x9.5 +35 fitment. That setup is ideally meant for the Evo 8/9 and not for the Lancer based on the fitment. For those looking to push the limits of aggressive fitment they can run the wider 18x9.5 +35 model but it will take some serious fender work and camber
-Dan
-Dan
This model is meant as a direct bolt on setup and will even fit on a lowered car without fender work. Overall fitment will depend on variables such as tire size, alignment, spring rate, etc.. however the majority of our customers have yet to report rubbing with this fitment
-Dan
WheelDude.com
158
Mar 5, 2016 07:10 AM
WheelDude.com
186
Oct 13, 2015 08:37 PM
WheelDude.com
Jun 15, 2009 04:39 PM
WheelDude.com
Aug 3, 2007 05:23 PM
