Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
alignment help
Old Aug 26, 2010 | 04:21 PM
eyekyu's Avatar
alignment help
whats ideal for lowered cars? i wanna go pretty agressive w/o buyin new tires every few months lol
is it possible to go -1.5 deg camber all around and toe 0. how do they adjust caster
any help, ive tried search but i think im confusing myself
thanks
Old Aug 26, 2010 | 06:51 PM
EngRWW33's Avatar
thanks
Assuming that you have camber bolts for the front, and a camber kit for the rear, I would recommend -1.5/1.0 f/r, 0 toe all around (what i am running and it feels good without sacrificing too much wear on the inner tire). without the camber bolts/kit, only toe is adjustable.
Old Aug 27, 2010 | 12:02 AM
WangMan's Avatar
camber really isn't important unless you plan on tracking your car or you're trying to squeeze rims into your fenders that wouldn't otherwise fit. If you're doing neither, I'd suggest running 0 camber, which is what I'm doing. No need to wear your tires unless you've got a good reason to
edit: camber bolts are still a good idea though if you're lowering even if you don't plan on going with an extreme degree. Your camber will change based on the amount you lower your car and camber bolts are needed to adjust the camber to your liking, whether its -2 or 0
Old Aug 27, 2010 | 08:35 AM
eyekyu's Avatar
the front will be on a camber plate from the coilovers, but nothing in the rear. with that being said it sounds like i cant get camber in the rear, correct?
Silver-IXse
May 8, 2013 08:53 AM
deworley
10
Nov 29, 2011 03:54 PM
asu11
Sep 22, 2011 10:10 AM
Evofletch
Feb 27, 2011 02:40 PM
clubEVO93
11
Jan 3, 2011 07:05 AM
