Eibach Pro-Kit bump stop question
So I've been reading the debate for awhile about whether or not you should cut your bump stops. The picture below is the stock bump stop/dust boot on the right (from a 2009 Lancer GT) and the new one on the left I got in my eibach pro kit.
So my question is, why would you cut the stock bump stop when Eibach includes a new one in the kit?
Did they maybe just start adding these in the kits so people didn't have to cut anything? Also does anyone have any experience with the Eibach bump stop? It just seems to move a lot easier on the strut than the stock rubber one did. Not sure if that's normal or not.
So I called Eibach to confirm. They said definitely use the bump stops in the kit. He said if they provide bump stops in the kit it means they're supposed to be used, which makes sense. Hopefully this will help others if they have the same concern.
ryangabriel2115
May 31, 2013 03:52 AM
ProjectGSX
May 27, 2012 07:15 PM
ProjectGSX
Sep 19, 2011 04:48 PM
