Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
ralliart springs!
Old Feb 4, 2012 | 09:23 PM
Paintabruh's Avatar
ralliart springs!
hey are the ralliart springs shorter then an LS spring sorry if its dumb questions just wondering
Old Feb 4, 2012 | 10:58 PM
jujukiller's Avatar
DUDE stop, you have to learn to search, I know some people on here may come off as mean for asking you to search, but it's for a reason. This just friendly advice just search a bit before you make a new thread.
It took me 5 seconds to find this:
https://www.evolutionm.net/forums/la...uspension.html
"They do fit. I asked rrm I believe about putting them on an ES. They said I just had to swap out the top mount for the ES. After that, I could use OZ or Ralliart since they where both the same."
"yes you can use ralliart springs on OZ...It will lower the car for about an inch
I do suggest you use the ralliart struts too as they are a bit stiffer and improve handling"
Old Feb 4, 2012 | 11:25 PM
Paintabruh's Avatar
sorry will do, thank you for the info so i need ralliart mounts and and get the struts to ?
Old Feb 4, 2012 | 11:40 PM
jujukiller's Avatar
The ralliart springs can be used on OEM struts:
https://www.evolutionm.net/forums/la...-question.html
You would have to change the top mounts if you want the ralliart struts, they are a bit stiffer.
Old Feb 4, 2012 | 11:55 PM
Paintabruh's Avatar
Ok sweet az and so really no different getting rally springs?
Old Feb 5, 2012 | 04:41 PM
jujukiller's Avatar
no doesn't look like it unless you get the struts with it
Old Feb 5, 2012 | 10:33 PM
Paintabruh's Avatar
ok sweet az
markspd6
Dec 5, 2016 04:59 PM
s84kam
Apr 8, 2011 08:11 PM
Fifty
For Sale - Wheels / Tires / Suspension / Brakes
Aug 28, 2010 08:46 AM
FunkyR
Apr 4, 2007 07:31 PM
JT-KGY
14
May 10, 2004 09:55 AM
Quick Reply: ralliart springs!
