KYB GR-2/Excel G shocks/struts, Whats the difference between 2002 ES vs. 2002 OZ/LS?
Why does KYB have different part numbers for the KYB GR-2/Excel G's for the 2002 Lancer ES vs. the 2002 Lancer OZ/LS?
Would the struts meant for the 2002 Lancer OZ/LS be better (upgrade?) for a 2002 Lancer ES?
Whats the difference? dampening?
Seems the OZ/LS versions are cheaper by a few bucks usually..
why?
Anyone know for sure?
I'm getting ready to pull the trigger on getting the suspension back in shape because I now have a bad inner tie rod..
why?
Regardless of the upper strut mount, what exactly is "slightly different" ??
Is this heresy or hands on experience? Is there a tech sheet that shows you some sort of difference in measurement?
I'm installing a set of Excel G/GR2's today.. I got all 4 for $300 shipped.. pink KYB Excel G box's
done wid it..
I went ahead and did the inner and outter tie rods while I was in there.. a bit of play before..
Night and day difference..
I'm looking to order a rear sway bar too..
It's hard to believe there wasn't one on a IRS setup..
Ok so I also have the same question about the struts. Right now I just need struts for my 02 ES. I don't care nothing about brands or dropping the car.
As for the strut mounts being different from the ES to the OZ / LS, I'm guessing that's BS..... When I look for just the strut mounts every brand shows that they fit ES OZ and LS. So if the mounts ARE the SAME then why wouldn't OZ struts fit my ES? I'm sorry to sound like a dick but I have looked over this forum and all I have found were BS replies like They are different fits, just get what is for YOUR car. DUDE THAT DOESN'T HELP.
Is there anybody on here that knows how to do more then just bolt parts on to there car?
as for the fronts, the body length, piston length, travel length are different, and the mounts are different.
The total length is the same though. The springs don't seem to have the same diameter (though I never measured them).
here are the 2 models specs, you will sort out which is for which model, if you know better than just threading bolts
http://catalog.monroe.com/catalogPar...dStatus=ACTIVE
FYI, for a Lancer 2002 ES, like yours, I got my mounts from Monroe, my struts from Sensen - to have the cheapest set possible ever, cost me 210$ off rockauto, these struts are good so far, read on mazda forums they were fine so I tried.
I did a quick write up on the rear here:
https://www.evolutionm.net/forums/la...l#post10098019
Monroe OE SpectrumŽ 72142 http://catalog.monroe.com/catalogPar...dStatus=ACTIVE
2002 Mitsubishi Lancer Strut Assembly Front Pair (excluding ES Models) ( Monroe)
2003-05 Mitsubishi Lancer Strut Assembly Front Pair (excluding ES Models) (excluding Evo Models) ( Monroe)
2006-07 Mitsubishi Lancer Strut Assembly Front Pair (excluding Evo Models) ( Monroe)
Monroe OE SpectrumŽ 72141 http://catalog.monroe.com/catalogPar...dStatus=ACTIVE
2005 Mitsubishi Lancer ES Sedan 4-Door
2005 Mitsubishi Lancer Evolution MR Sedan 4-Door
2005 Mitsubishi Lancer Evolution RS Sedan 4-Door
2005 Mitsubishi Lancer Evolution Sedan 4-Door
2005 Mitsubishi Lancer OZ Rally Sedan 4-Door
2005 Mitsubishi Lancer Ralliart Sedan 4-Door
2004 Mitsubishi Lancer ES Sedan 4-Door
2004 Mitsubishi Lancer Evolution Sedan
2004 Mitsubishi Lancer LS Sedan 4-Door
2004 Mitsubishi Lancer OZ Rally Sedan 4-Door
2004 Mitsubishi Lancer Ralliart Sedan 4-Door
2004 Mitsubishi Lancer Sportback Wagon
2003 Mitsubishi Lancer ES Sedan 4-Door
2003 Mitsubishi Lancer Evolution Sedan 4-Door
2003 Mitsubishi Lancer LS Sedan 4-Door
2003 Mitsubishi Lancer OZ Rally Sedan 4-Door
2002 Mitsubishi Lancer ES Sedan 4-Door
2002 Mitsubishi Lancer LS Sedan 4-Door
2002 Mitsubishi Lancer OZ Rally Sedan 4-Door
