Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Rim/wheel NUB
Old Nov 21, 2013 | 12:48 AM
Newuser213's Avatar
Rim/wheel NUB
I just got a 2012 Lancer ES and I wanted to swap the
hub cap wheels with some rims but I dont know
what will fit the ES. Brands?
Old Nov 26, 2013 | 06:27 PM
Ichigo0Soul's Avatar
Any wheels that are 18 inch in diameter by 8 inches wide with a bolt pattern of 5x114.3 will fit the car. With that particular wheel size, you'd want tires with a sidewall of 45 and tread width NO WIDER THAN 225.
Old Nov 27, 2013 | 06:12 PM
Newuser213's Avatar
Would I need to roll the fenders(just found out what this means), what are some decent brands? I see there are some rims out there that are like $90 each, I find that kind of low... is it?
Old Nov 28, 2013 | 10:04 AM
If you get rims wider than 8.5 inches coupled with tires that are 225 or wider, you'd need to have your fenders rolled. Otherwise it'll rub REALLY bad and you could easily shred your tires and have yourself a blowout.
And if you aren't doing anything with the car that requires some crazy lightweight and strong rims, the $90 rims they have at pepboys would suit you just fine. And if you want to keep the same tires, I'd recommend going with the same size rim as what you already have on the car.
Let's say your current tire size is 215/55/R17. That'd mean the tire width is 215mm wide, the sidewall is 55, and the rim is 17 inches in diameter.
You can find a guide on how to read tire sizes here.
Old Dec 3, 2013 | 02:05 AM
Newuser213's Avatar
http://www.pepboys.com/product/detai...72/?quantity=1
saw this but I read/saw people saying these are cheap
and would break easily... what you think?
What are some good brands?
Kayvee413
Oct 24, 2017 07:07 AM
cognizio
Outlander Sport
Sep 17, 2015 01:24 PM
aby_george75
Mar 23, 2012 04:27 PM
blackdiamonds
15
May 27, 2009 01:57 PM
