Clunking noise after swapping rims/tires
Hey guys so I need some advice as to what could be causing my problem since I can't get to a shop until monday. Any help would be much appreciated.
Here's my problem, I swapped out my 2010 Mitsubishi Lancer's 16" stock rims (205/60/R16 tire size) with my friend's 2006 Honda Civic SI 17" stock rims that I had a shop mount new tires on (215/50/R17) since the tires originally were too wide and would have some rubbing going on. Now whenever I drive I am getting a clunking noise that sounds like its coming from all tires (seems louder in the back tires). The clunking is constant and gets louder whenever I drive over any kind of little bumps. However, whenever I apply pressure to my brake the clunking instantly stops.
I researched online a bit and thought I had found the answer to my problems... wheel spacers. Since my lancer's hub center bore is 67.1 and the civic is 64.1 I figured I would just need 3mm wheel spacers. I bought them, installed them and it didn't fix a damn thing. I also made sure that the bolt pattern for both were the same (5x114.3).
So now I am stumped as to what possibly could be the problem. Thanks in advanced for anyone that can help me, and if you need more information / have any questions please don't hesitate to ask.
Okay so basically my wheel bores have just been bouncing up and down and knocking off the hub while driving?
So all I need is 67.1 - 64.1 hub centric rings and that should fix the problem?
Hmmm well the only thing I did was swapped out the rims and tires and there was immediate clunking. I made sure the lug nuts were tight, but I was wondering if it could be possible that the lug nuts are the wrong size and even though it seems I am tightening them all the way, it still isn't securing the rim all the way to the hub?
depends on the wheels and type of nuts...lug centric wheels require acorn nuts to center the wheel on the wheel studs...hub centric wheels sometimes use flange nuts, and the flange nuts fit loosely in the lug holes, but when torqued won't wobble because the center bore normally matches the hub...if you use flange nuts with incorrect center bore, they may clunk around.
I called a few car repair shops that focus on tires/wheels and they said I could just bring the rims to a machine shop to have them bore out the honda civic wheels so they are the same 67.1 mm size of the lancer's hub.
This seems like the simplest solution seeing as how I have already bought brand new tires and mounted them onto the civic rims. I'll be the first to admit I don't know jack **** about cars but it seems like this "bore out" of the wheels to fit my lancer's hub precisely should solve all of my problems. Especially since after matching the hub and bore sizes everything else would match as well (the bolt pattern and stud sizes are the same).... or am I completely wrong in assuming all of my problems will be solved?
If you go to this wheel cross reference site you can see that the 2006 honda civic SI and the
ralliartRA
Jun 12, 2014 03:26 PM
speedfreak24
38
Feb 9, 2012 12:23 PM
macPSU
Mar 16, 2009 04:41 PM
kpt6
Jul 3, 2007 08:34 AM
