Toyo Proxies
check out my site: www.Frisbyracetire.com. I'm the Toyo dealer for this site.
Any questions PM me.
Proxes 4 in a 205/40-17 is now only $82ea.
Proxes 4 - LOVE THEM. They hug the road, and traction is much better than my Goodyears were.
PS - while on the topic, tswift is the best, nicest vendor I've ever worked with.
i hear the proxes are a very good all-season tire. they are not recommended too much for track use because it heats up pretty rapidly, which is a good thing on the road, but for track use there's better tires out there. but the dry and wet traction is supposed to be a little better than the older proxes..not sure by how much but i guess it's noticible. Im not sure how it is in snow tho.
I have the new one - Proxes 4. Don't have the tech specs, as Toyo didn't feel like putting them on the site. Here's the details from Toyo.com, though...
Features and Benefits
Appearance
- Aggressive unidirectional tread design
- Unique "W-shape" tread pattern
- Modern high-image sidewall design
- Unique "4" logo on tread elements
Wet and Dry Handling Compound
- "Generation S" silica-reinforced, high-grip tread compound
- Unidirectional tread design High angle tread grooves to evacuate water
- Paired shoulder blocks to increase cornering grip
- Curving center rib to enhance directional stability
Steering Response
- T-Mode Design Technology
- Hard bead filler compound
- Two full-width steel belts
- High grip tread compound
All-season traction
- Unidirectional all-season tread design
- "Multi-Wave Sipes" in shoulder blocks
- M&S rated (that's mud and snow)
Quiet Ride
- "Multi-Wave Sipe" for reduced heel and toe wear
- Variable-pitch block tread pattern
- Jointless edge and cap ply construction
- Jointless bead wire
Durability and Tread Life
- "Generation S" silica reinforced tread compound
- 300 UTQG Treadwear rating
Appearance
Steering Response
All-season traction
Quiet Ride
Appearance
Steering Response
All-season traction
Quiet Ride
Appearance
Steering Response
All-season traction
Quiet Ride
My buddy just switched from goodyears to the Toyos on his new Trans Am. It was fatal to his rear end. It went from a tire burning machine to a tarmac remover. Shortly there after the added stress fragged the rear. Good tires
Im ridin on the Ts1's right now hug the road like a dream though NOT a winter tire at all and more than $85 per tire. But I love em none the less. Makes the stock brakes and suspension feel 100 times more controlled than the stock tires.
