Help With Fitment
Help With Fitment
Hey guys, I am currently driving a 2010 Lancer ES. I've looked around for wheels and tires and im really confused with all the specifications. I tried reading some more into understanding everything but i've had no luck. Im currently at stock height but i plan on purchasing coilovers in the near future. Im looking to see what wheel size everyone is running and what size tire. Send pics along with the setup!
Thanks for the help,
Charlie
Charlie
CharlieS3 (Feb 23, 2017)
205/60R16 6.5Jx16 ET46 5x114.3
215/45R18 7Jx18 ET46 5x114.3
(https://www.wheel-size.com/size/mitsubishi/lancer/2010/)
For the easiest fitment, I would follow these. Once you have coilovers on (gives you more space to work with since the coil is smaller in size than OEM) then you can consider going a bit bigger.
I have seen people go 245/40R18 with 9.5x18 +35mm.
I don't know if I need to explain tire size but just in case.
245 would be tire width, 40 would be wall height on side of tire and 18 well diameter.
9.5 is width in inches of rim, 18 diameter and +35mm is the offset.
This being said, I wouldn't go over 240/40R18 with 8.5x18 +35~38
GTB/ZR-1
Jan 2, 2014 08:43 PM
sna08
May 6, 2007 05:03 PM
jdub24
Nov 13, 2004 11:40 AM
ARVSHOP
Oct 12, 2004 10:18 PM
