Front and Rear Sway Bars
I am think of purchasing one. I would like to know if anyone can recommend the correct thickness for the best handling with little or none over and understeering. I am interested in Cusco.
Thanks.
Thanks.
you looking for them for the uslancer or the evo? if you have an evo, search in teh evo forums. if you are an es uslancer you can get the stock rear sway bar from the OZ (hot too great) or you can get the raer progress one like blacksheep already said.
As said above, there is only an aftermarket rear one available for the Lancer (non Evo) right now, but that's all you need unless you're running in the stock class for SCCA autocross (only to reduce body roll). Once you lower the car, you won't want a larger front one.
Originally Posted by blacklancer03
if youre not in super autocrosses or anything.. do you need the perches RRM sells?
-N
I agree, you'd still want the perches. Ironically, I've only heard of one set of stock perches being broken during an autocross while at least 4 people have broken them on the streets just taking a corner too hard or cruising canyons. The difference is that most autocross racers practice smooth transitions while the average joe yanks the steering wheel too much, so they're both at risk because of the load that will happen to the sway bar at herd cornering as well as snappy maneuvers.
Originally Posted by Wallesasuaz
Are we talking about the OZ or the other classes?>.... I heard that the OZ doesn't need the perches, or am i wrong?.... Just from what i've read.!!!
-N
WTT[MidWest]: Ams high flow cat test pipe for ets/ams test pipe
03redtype-s
Dec 26, 2016 07:49 AM
Chris@AMS
Aug 15, 2009 09:01 AM
