tranny problem
tranny problem
hey i have a question about my tranny every time i shift it sounds like somthing is rattling and when it ideals it just rattles. what could be the problem? is cluch shot tranny shot or somthing it just started to happen tonight. need help asap thanks.
What rattles? Where does the sound come from? Is there vibrations too or just a sound? If you can drive you car and shift, I'm going to go out on a limb and say that nothing is "shot". Cars make tend to make lots of rattling noises, as the entire thing is held to together by screws and bolts that come loose over time.
it rattles when i shift. right under the shifter it self like it's comming from under the car. there is no vibration. but only does it when im in 1st 2nd and 3rd only. i dont really know how to enplane it but thanks for the help.
easy thing to check out, get under the car and make sure the heatshield is not hitting the exhaust or body, that is usually the cause of rattles on lots of cars especially in tha manner you described
I got my lancer 3 weeks ago and it's doing something similar. Not so much a rattle but like the shifter is catching something. Doesn't always happen, but yeah 1st to second and sometimes 3rd. This is with the clutch fully engaged to the floor, so the gears aren't touching, it feels as if its catching right under the shifter.
I'm going to take mine in but I was wondering if you herd anything about yours?
Is it tough to get into any of those gears when it does make that noise? Linkage binding or more likely just metal on metal contact from what was already mentioned...the exhaust heat shield.
PattonX
10
Feb 21, 2010 10:56 AM
