Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Manual transmission - downshifting / Heal and toe rev matching
Old Jun 11, 2009, 10:25 AM
s84kam's Avatar
I've been driving manual for years and i've only tried the heal and toe only when i try to drift a rear wheel car. For all the times i've been driving i've always used my downshift to slow down. I'm hearing too many mixed answers. Out of curiosity I just want to ask if any of you guys actually use the heal and toe technique to slow down or just using your breaks?
Using the tranny to downshift, does this cause any premature wear of any sort?
Old Jun 11, 2009, 10:45 AM
MasterAK's Avatar
Heal and toe implies the usage of the brakes so you actually use the brakes to slow down before entering a corner while rev matching at the same time.
Old Jun 11, 2009, 11:10 AM
ambystom01's Avatar
Bingo, heel-toe is somewhat useless around town, rarely do you get into a situation where you need to hammer on the brakes while downshifting at the same time. For the most part, I leave heel-toe for the track and just rev-match around town if I need to downshift. Using the tranny to brake is a bit silly, brake pads are cheaper than transmissions.
Old Jun 11, 2009, 11:16 AM
Greedy_son's Avatar
Dont think downshifting will cause premature wear. If you do it properly (match your speed to gear ratio) its safe and wont cause any damage while saving your brakes, now if you downshift from 5th gear to 3rd this will cause some damage .
Old Jun 11, 2009, 11:20 AM
ambystom01's Avatar
If you're using the transmission to slow down, it causes a bit of wear. How much is debatable. I'd still rather use the brakes than the transmission unless you have miles upon miles to slow down.
Old Jun 11, 2009, 08:53 PM
s84kam's Avatar
yea that sounds about right, brakes are cheaper than transmissions. Gotta keep that in mind if i want my lancer to keep lasting a long time
Old Jun 11, 2009, 10:16 PM
azn_ghetto's Avatar
i heal toe when downshifting, its a way of rev matching when braking, i realized when i started using heal toe, my downshifts have been signifcantly smoother
Old Jun 11, 2009, 10:23 PM
evoDON's Avatar
i just rev match around town. no need to really heel toe. but it does help on the track
Old Jun 12, 2009, 04:28 AM
kalpakiotis's Avatar
the only extra wear downshifting will cause is to your clutch plate. The gears are all high grade steel and as long as your not mashing into the gears you should never have any real problems with it. It's debatable on how much wear it'll cause, but I don't care that much about it since I plan on replacing it with something better in the future.
Old Jul 16, 2009, 07:32 PM
djslik408's Avatar
Still brake pads cost a lot cheaper.
Old Jul 17, 2009, 06:42 PM
SirLancerlotWPG's Avatar
And alot easier to replace yourself.
Old Jul 20, 2009, 01:57 PM
LanceHer's Avatar
How the heck do you guys heel-toe in this car?! The pedals are too small in my opinion or just too wide apart.
I have tried many times but to me it seems the gas pedal is too low, and i really have to jam on the brakes to get the heel to blip the gas.
It only works perfectly for me when i am wearing an old pair of wide shoes. But this is stupid because sometimes i catch the brake with the shoe edge while pushing in the clutch with the left.
Did any of you put a pedal cover on the gas to give it a little height?
Old Jul 20, 2009, 08:54 PM
absolute's Avatar
well even though its called heel-toe
u dont actually use ur heel. its more like the lower right side of ur foot. and the ball of ur same foot to apply pressure on ur brakes.
and no i didnt give my gas pedal any height, its just practice its a bit different on every car right. u probably just need to tilt ur foot a bit more to the right and blip ur throttle a bit harder
Old Jul 21, 2009, 07:47 AM
ambystom01's Avatar
It depends on the person, I very much use my actual heel. Try moving your foot higher up on the brake pedal.
Old Jul 21, 2009, 09:46 PM
djslik408's Avatar
Sooooo heel toe huh. It seems that a couple of people have different definition of it.
Quick Reply: Manual transmission - downshifting / Heal and toe rev matching
