Evo transmission fwd
I know the evo transmission does not bolt up to the 4g94. What I am trying to do is gather information on the swap im now saving for. Im going to purchase a evo 8 or 9 engine and swap them into my 02 oz. And i know i can use the f5m42 transmission but you can normally purchase a transmission and engine cheaper if they are still together. So what i was wondering is if i can remove the evo's transfercase and keep it just fwd with custom axles? I tried searching and found nothing any info would be nice thanks.
josh
Yep started looking into the swap the next day. I want more :P But i dont want an evo or awd. I like working on and having things that are different. When ever i take the car to the track all the v8 guys that line up next to me are all worried and ask is it an evo as soon as i say no they start talking smack. So i want to give them a reason to fear a lancer that is not an evo :P And the power levels that i want to be making are not within reason for this engine. I think the swap would cost less. I want to be atleast 500 whp. so i could keep stock evo bottem end and only be paying for the swap probably around 3k isk is what i expect.
Yup! lol I like challenges and i think this would be one plus gettign it to get traction would be anouther :P But back to the main point does anyone know if you can remove the transfer case on the evo transmission on and run it like a fwd only transmission?
Ok, here's what I got. To just remove the transfer case and install the passenger side axle, you would have a good 8" or so of the output shaft being exposed between the transmission oil seal and the axle. I wouldn't recommend this.
So to use the Evo transmission sans transfer case, you would likely need to disassemble the transmission to remove the Evo's center diff assembly and find a suitable replacement from a FWD Mitsu (likely an Eclipse). You would then need to find an axle combination for both driver and passenger side that would work with the right outer spline and length of the Lancer and the inner spline to match the diff assembly you went with.
All in all, it doesn't present itself as a simple swap and go. There are alot of maybes in there. The much better FWD transmission option is using the F5M42 trans from the 3G Eclipse or the Lancer F5M42 with the 4G64 bellhousing.
The turbo'd 4G64 Eclipses are pushing 350-450. You would figure that anything higher than that would be annoying to drive as a FWD setup. I would recommend having the rails, forks and gears prepped for the abuse you intend to put them under. And, of couse, an LSD will be necessity.
apoopoo999
Jan 1, 2023 02:08 PM
ZanarkO
Nov 11, 2015 10:52 PM
decoder
Nov 26, 2003 06:35 AM
