Short Shifter Install
Alright boys n gurls here's a detailed explanation on how to install the B&M shortshifter so you don't have to waste an hour and a half doin it...
1)Remove the two screws from the bottom of the big compartment of the center console
2)Pop center console off (connected by snaps at the front of the console)
3)Pop off small front piece under the glove compartment (connected all by clips)
4)Pop off small front piece under steering wheel (ther's one of those pop screw thingys u need to get out)
5)Behind the front pieces on both sides there is a pop screw thingy on each side -- push the middle to pop them out
6)Pull front center console out (the shifter should be exposed)
The rest of the install can be done with the instructions provided with the shifter -- they're pretty detailed...here are some tips though:
-The pivot cups were freakin hard for me to pop off...I spent like 30 mins on both of them...your best bet is to use a wrench and cover the cup with a tshirt and try to pop it off with the wrench
-Remember how the shifter spring sits on the shifter...took me a while to put it in right
-Use rediculous amounts of grease...I greased it up so much that when I put the cup back on a buncha grease flew everywhere cuz I used so much...that's definitely the way to go =)
-Grease the big pivot ball in the middle of the shifter...the instructions dont say to but its a good idea...I did it
-Get a non-metallic shift knob...the summer heat is a killer and you'll burn your hand on a hot sunny afternoon...I jes drive with a tshirt over my shift knob...ghetto eh?
I think that's about it...hope this makes all your installs easier then mines
Originally posted by agsmooth84
very useful but that kinda makes me not want to attempt this on my own.....im scared
Did mine last Thursday... hardest part is separating the shifter ball from the socket... Use the kitchen counter or equivalent... Rest the socket on the edge, and apply firm pressure by pulling down on the shifter... When you hear the pop, look where the socket flies... and recover it...
I also did the bushings at the same time... Definately worth the extra time and the few $$'s on the install... Shifts now feel shorter, more precise, and there is a mechanical feel to them...
I also got the B&M short shifter.... it's easy for me to get 2nd gear scratches (car is modified) every time now and the shifting is much quicker... with no time wasted between gears.. Hardest part for me was getting the center console out.
TWM Performance
Feb 28, 2017 07:36 AM
Kracka
83
Jan 20, 2017 12:54 PM
webguy330i
Apr 12, 2004 11:53 PM
