Triple Disc Clutch?
Triple Disc Clutch?
What is a triple disc clutch? Saw it on an ad on evom
heres the link:
http://www.boost-solutions.com/
heres the link:
if the torque produced by the engine exceeds the friction and clamping force of a clutch, then you need a clutch upgrade. having 3 discs in your clutch multiplies clamping force by 6 since there are 2 surfaces per disc. etc etc. that's the idea.
say your drive train was two parts. it would be your engine and then your wheels (over simplified). the clutch connects your wheels to the engine. since the clutch can only support so much initial torque, it will slip if the engine produces more torque than the clutch disc can grip. so if you're making more torque than the clutch is good for, upgrade it.
saxon
Apr 29, 2016 09:57 PM
vagelisix
Sep 23, 2013 07:06 AM
EvoRs
Jul 16, 2004 05:46 AM
