do the OZ come with antilock brakes?
Do the 2002 OZ come with antilock brakes? and my brake pedal goes almost to the floor before stopping......is that norm. with these cars? and keyless entrey
No, none of the lancers have anti-lock breaks (ES,LS, OZ). It is not normal to have to push the pedal all the way down.
Have you ever had your breaks serviced? If you've had the same break pads on for awhile now it might be time to switch them out. Have them checked out and also your rotors, because if your pad is low it is possible you are damaging or warping the rotors now. Consult your owners manual for apporpriate service times.
Fox
Fox
huey- you've probably burnt up your brake fluid (it breaks down with use and starts to be more easily compressible as it breaks down). you're mileage would be good to know, too. If you're in the 25K range you may just want to install new pads and replace the fluid with a higher rated fluid- I went with the same DOT rating, but my fluid is designed for SUVs and trucks- I'm really hard on brakes, especially at autocrosses. I recommend the axxis pads for daily driveability with good performance braking, too.
GrannyShifting
Mar 21, 2017 05:25 PM
