Aem Intake Problems
Old May 30, 2005, 05:15 PM
jcamfm's Avatar
Aem Intake Problems
i just installed an aem cold air intake in my 2002 OZ Rally Lancer....but when i plug in the maf senser into the maf itself it runs like crap(can i say crap on here...what ever) i tried to drive it about 30 miles to reset the computer but it not reseting... i know that the new upper pipe makes it so that the maf is farther away from the block and that is why when i plug it in it feels like my engine isn't getting enough air...but when i unplug the maf it runs like a champ....but(yes another but) the check engine light stays on...now is there any way other then sticking black tap over the check engine light so that i can plug in maf senser and have the computer except it....
Old May 30, 2005, 05:21 PM
purecoda's Avatar
1. double check all of your connections, make sure your hose clamps are tight and everything is properly installed facing the right direction
2. disconnect your negative battery terminal and let it hang for a short while (this is what resets the ecu
3. fire it up and let it idle for about 10 minutes or so. after that you should be good to go, it will take a while for the ecu to "learn" the new intake but it should still run fine
if this doesn't work, i don't know what the beef is. what other mods do you have?
Old May 30, 2005, 07:48 PM
03RallyLancer's Avatar
are you sure its your maf u are unplugn? your car should run like **** w/o it. as your engine does not know how much fuel to add
Old May 31, 2005, 08:18 AM
oz4g94's Avatar
you may have it on backwards.
Old May 31, 2005, 11:50 AM
give us a pic and circle what you are talking about
if you dont have a digi camera... use the engine shot in my registery.
Old Jun 5, 2005, 11:24 PM
felony's Avatar
I bet its backwards
Old Jun 6, 2005, 12:12 AM
Archangelite's Avatar
did you run your car idle for 15 minutes after you plugged your battery back up?
Old Jun 6, 2005, 12:25 AM
Z_Lancer_Man's Avatar
Your intake should look like this setup. Notice the direction of my MAF.
Old Jun 6, 2005, 07:59 PM
u can have it facing up... the wires reach... i know when i installed mine i accidently did it that way and have never turned it over.
Old Jun 6, 2005, 08:06 PM
Yeah it can be rotated. I like mine like this - the wires are hidden.
Kralster
Lancer Troubleshooting
Jan 11, 2023 10:26 PM
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
DONNOD
May 9, 2014 05:42 AM
goodhart
Jul 19, 2011 03:51 AM
Euripides
12
Feb 1, 2010 08:14 PM
Quick Reply: Aem Intake Problems
