RRM Test pipe buzz..
Old Oct 14, 2005 | 04:14 AM
sykou's Avatar
I have the RRM test pipe on my car and since i installed it, i've been hearing this buzzing sound every time i rev the engine. I think its an exhaust leak since its only coming from the test pipe. I tried tightening the bolts on the pipe but i don't really know how tight to make them.. If i use a ratchet and a 3 foot pipe to add more leverage about how tight should i make it. Untill i can't turn it any more or what? thanks
Old Oct 14, 2005 | 08:15 AM
SLVROZ_03's Avatar
Maybe give RRM a call about the ft/lbs. I'm sure they have it in the books somewhere.
Old Oct 14, 2005 | 11:24 AM
sykou's Avatar
How about anyone who has the test pipe on their car now. How tight did you guys make it?
Old Oct 14, 2005 | 11:27 AM
datdjrobp's Avatar
i don't remember from my install....are there gaskets to worry about?
Old Oct 14, 2005 | 01:24 PM
SLVROZ_03's Avatar
Yeah, about the gaskets. When my brother put on a test pipe in his Integra, he used two gaskets for both sides. Maybe that would help...
Old Oct 15, 2005 | 02:51 PM
sykou's Avatar
oh yeah maybe i should try that... anyone else on how tight they made theirs???
Old Oct 15, 2005 | 05:11 PM
03RallyLancer's Avatar
if you didnt put in any gaskets then you probably have an exhaust leak... and just wrench em down nice and tight... dont really need a trq figure on that.
Old Oct 16, 2005 | 06:26 AM
sykou's Avatar
Oh yeah about the gaskets...did anybody else have a hard time lining up the gasket with the front part of the header??? the side closest to the header. The bolts i got are a little small for the holes so i had to use the washers that i got with them to make them hold. Since the bolts were too small for the holes, the gasket didn't really match up to well and i kinda had to guess where to line it up. could this be where my exhaust is leaking from...
and another thing... when i removed my stock cat, the old gaskets were stuck all over the joints. Anyone know how im supposed to get the old gasket off the pipes???
Old Oct 18, 2005 | 12:34 PM
Kelspar's Avatar
When i installed my cat pipe, i still had stock muffler and it buzzed like hell. Sounded ricey; when i upgraded to Mangaflow catback it went away. Food for thought if your still stock on the back side.
Old Oct 18, 2005 | 12:36 PM
Kid Lancer 7's Avatar
Bro ive had mine on since january.. and i JUST started hearing this noise yesterday!. I thought it was my rear bumper but i doubt it.. so you are not the only one!
Old Oct 18, 2005 | 12:40 PM
yeah an my exhaust tone went from really nice to really rice.... its weird how both of us have this happening at the same time.. i gotta get to the bottom of this.. it really urks the sh8t outta me when it buzzes
Old Oct 19, 2005 | 04:59 AM
sykou's Avatar
WOW! mines is about a year old too. Anybody think it might be a manufacturer defect?? Or maybe its just wear and tear.
Oh and another thing, when i took off my test pipe, the gaskets were COOKED. I could see a black area where i think the exhaust was leaking from. I bought new gaskets and installed them today and no matter what i tried , the buzzing just wouldn't go away...
And here are a few things i found out while swithcing the gaskets...
1) When you first put the new gaskets in, you won't hear much of a buzzing sound but if you rev your engine while looking under the car you'll se that their is some condensation dripping out from the joint.
2) As you drive your car the heat fries the gaskets, due to the leak, and thats when you hear the buzzing sound. Due to the deterioration of the gaskets.
3) tightening the bolts doesn't help solve the leaking or the buzzing.
4) Turning the gaskets around doesn't eliminate buzzing or leaking.
well thats all i can think of now.. If anybody else has figured out a way to solve this problem please POST.
Old Oct 19, 2005 | 07:35 AM
ok sykou.. i got a lil update. it was bugging me so much that i went to mineke so they can have a look....
#1 they found out my Resonator on my catback exhaust had a huge hole in it. Huge exhaust leak. (i have a steep driveway i think the concrete ripped it open everytime i scraped) So i had them weld a straight pipe in its place ($60 ) untill i get a greddy resonator from RRM.
#2. I still hear it buzzing... but less then before... sounds like loose bolts or something.. it could be the gasket.... Im gonna jack up the car to get a closer look.
Old Oct 19, 2005 | 11:13 AM
twardnw's Avatar
on a chunk of pipe? not very likely at all
and if you want a torque figure, let's say 45 ft/lbs for ****s and giggles
Old Oct 20, 2005 | 01:39 PM
sykou's Avatar
maybe the stock muffler creates too much back pressure and it causes the leak thru the gasket... I'm almost about ready to get rid of the test pipe... Is the only way to get rid of the sound to get a straight pipe, or a high flow cat welded on instead of the bolt on test pipe? dam this sucks..
Quick Reply: RRM Test pipe buzz..
