Rough idle
Rough idle
When i start my car it will idle fine until it warms up and then the it will sart to idle rough/sputter. If you rev it up alittle it might smooth out for a bit or it might not. i'v been having this prob for about 2 months now. The code that i pulled is p0300 random/multiple cylinder misfire detected. When i drive it, it seems to drive and boost fine and there is no lose in power also no knocking or pinging. What i'v done so far is replaced plugs,wires and coils,maf sensor,o2 sensor only because i was getting a code for that also because of damage when i installed turbo,checked egr valve operating prop,did a compression test which they all read around 185 to 190,pcv valve,checked for vac leaks.Also when iturn on the headlights or anything that migh draw alittle power the fuel pump will change pitch for a second and the car will idle better most of the time. Also when it starts to idle rough the boost gauge vac will go from 20 to 15hg? Any new sugg would be appreciated.Thanks.
take your spark plugs out and look at the crush washers. if there's dirt there, wipe them off. now look down the hole where the spark plug goes. if theres dirt where the spark plug seats, scratch them off with a long thin stick thing. i used a bbq skewer. then disconnect the crank sensor or spark coils and crank the engine a few times to get the dirt out of the cylinder and the shaft. repeat for each cylinder.
thanks for the advice,it's been raining in wis for the past couple of days and i have no garage so ill try the next dry day,anyone else have any suggestions.
Engine=RRM intercooled turbo kit,RRM crank pulley,test pipe,Thermal R@D catback ex,Greddy type RS bov,turbo xs mbc. Suspension,Sprint springs,Progress sway bar,RRM rally spec strut bar,17" tenzo sinko wheels,fuzion zr1 tires,Interior=Autometer carbon series gauges,boost,oil press,airfuel,volts,HKS turbo timer,beltronics vector performance meter,Apexi super afc 2 for monitoring purposes,carbon fiber glove box insert. Ext=RMR body kit,RMR wing,carbon fiber hood,tinted windows,RRM slotted roters.
when i installed my intercooler a couple of months ago i took the ground that leads from the frame to the cam gear cover off so i could get a the last bolt from the header easier and when i put it back on i forgot which of the 4 bolts it went on and how. Anyone got a good close up pic or could run out and check theres. Thanks.
need_an_evo
Mar 29, 2016 09:14 AM
02, 2002, 2006, alternator, es, evolutionm, idle, lancer, mitsubishi, oz, rally, rough, sputters, wont
