MAF sensor help
MAF sensor help
OK.. in my other post I stated that i was being a dumbf*ck and took out the honey comb thing in front of the MAF sensor. Now my car wont idle at all. I just called the dealership and a new sensor cost 259.68. I was wandering is the a cheaper way to just get rid of this sensor. THanks for all the help
i think you should be looking for a MAF with the number #605 on it? or am i wrong?
www.msrecycling.com should be somewhere down there.
You guys are going to laugh sooooo hard. ok.. Since I have no money and a new MAF cost 260.00 dollars. I decided to get creative. I went to Jack in the Box and took about 50 staws. The next morning I spent 2 hours glueing the staws into a honey comb looking thing. I will post pics tommorow. but anyways... I put the staws in front of the sensor and now it works perfect. So I saved 260.00 bucks...
I already reset the ECU. I also installed some mesh between the back of the sensor just incase the straws break. Its crazy how good it works.. you would never know straws where in my intake.
MAF is a sensitive measuring instrument. For other guys is the future, do not tamper with it! Good luck finding one. Try PITSTOP in Sun Valley. They have a lot of Mitsu parts.
ROAD/RACE
http://www.roadracemotorsports.com/
ROAD/RACE
![Pimp](https://www.evolutionm.net/forums/images/smilies/pimpflash.gif)
![HeadBang](https://www.evolutionm.net/forums/images/smilies/headbang2.gif)
But I would only use it as a temporary fix since the heat under the hood may start melting the straws or at least make them sag over time.
Just a thought, I'm sure you don't want a bunch of melted plastic in your intake.
You can also go to the junk yard and find a DSM with the honeycomb and pull it out and trim to fit the EVO. Use a pencil and a piece of cardboard at the end to carefully push it out.
Good Luck
HAHAHAHAHAHAHAAAAAAAAAAAAA
why didnt you just put the honey comb thing back in?
dude if the glue goes on that your gonna start sucking the straws into your motor
its like the shot from the fast and furiouse
were you see the nitrus goin into the car
only i see red straws flying through the tubes and then a big ol valve cocmes and gobbles em up like suckie the dog!
