my lancer is HOT and i mean over heating
An addition--you may not find foam in the oil (antifreeze) or oil in the water--you can burn anitfreeze by blowing into the cylinder- you will also get air bubbles in the radiator...could get some pressure as well. Will get wht'ish smoke out the tail pipe..as for the over heating, My statement stands-- unless for some reason the configuration is cast block and Iron head...as for heat and expansion and contraction causing a head gasket to go...mixing alum head and cast block and you have exactly blaze125 was eluding too..expansion at diff rates causing you to lose a head gasket.. I just went thru this with my datsun--, been thru it a numbers of times with diff cars for diff reasons..This time the car only reached maybe 240* and thats all it took..Regardless...hope that isnt the problem, hope you got lucky, and all is well.. So whats the latest?
Blitzflip
12
Jul 4, 2010 10:54 AM
2003, antifreeze, appearing, bubbles, engine, evolutionm, heating, heats, lancer, oz, pubbles, radiator, recommended, shoots, water
