brake noises....
brake noises....
when i let off the brake as im inching forward there is a rubbery like deep noise coming from the brakes...this happened before i installed my rotors, and still happens. but only now that ived installed the power slot rotors, it makes a clicking sound as i brake along with that other noise. any ideas? id like to fix this before my dad comesh ome so he doesnt smack me(though he has a valid reason for doing so) for screwin up the car again!
Keep in mind what I say is purely speculation. I can't give an accurate diagnosis unless I was checking out your ride first hand. Jack your car up (preferably on the side you hear a click) and check how your parts are arranged, make sure everything is where it should be and that nothing is rubbing/touching/on fire. There have also been other reports of clicking from the wheel area and could possibly be a CV joint. Take a look around Troubleshooting and see what you come up with.
i found out that it was the pads rubbing on the calipers as the closed.....so i just drove hard till the tops wore down and didnt rub nemore...the lazyy mans solution
CodyJamesBitxh
Feb 9, 2017 07:13 AM
Jozino
Nov 14, 2011 02:00 PM
ddcha
42
Mar 14, 2007 09:41 AM
YellowOZ03
Jul 7, 2003 02:41 PM
