everytime i put a new fuse in it blows.
Old Feb 15, 2008 | 02:44 PM
mirage 4g93t's Avatar
is it a shortage?
Old Feb 15, 2008 | 02:47 PM
tabio42's Avatar
which fuse?
Old Feb 15, 2008 | 02:48 PM
sabastian458's Avatar
close. drop the age and you got it. It is a short to ground. Your circuit is either drawing more amps than the fuse it rated, or you have a break in one of the wires and that break is touching a ground to the chasis somewhere
evo823's Avatar
same thing happened to me i new something was grounding out the problem is finding out what it is for me it was a wire from my gauges
Old Feb 15, 2008 | 02:52 PM
tabio42's Avatar
Is it blowing as soon as you insert the fuse? Or do you have to do something for it to blow?
Old Feb 15, 2008 | 02:58 PM
it blows as soon as i put the fuse in. its a 7.5 fuse and drivers tailight and drivers parking light dont turn on.
my alarm system was installed by best buy 2 yrs ago. do you think i should go to them?
Old Feb 15, 2008 | 03:03 PM
o by the way. i have 2 gauges installed. i uninstalled them along with car stereo system and the fuse still blows.
Old Feb 26, 2008 | 12:26 AM
Buggzyy's Avatar
try this remove the bulbs from the sockets and try it if it blows then trace that wire to the nearest connector and disconnect it try again and keep tracing it back to the source of the problem probably not the alarm because you would think it would effect right and left sides.
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Mar 15, 2014 12:23 AM
Quick Reply: everytime i put a new fuse in it blows.
