rattling from dash
rattling from dash
I have quite an annoying rattle coming from my dash area. Have not been able to pinpoint it, car has 700 miles. Any1 having the same issue?
yeah buffalup, I have 15,000 miles on my GTS and I have been getting this rattle recently. I have definitely noticed it moreso in the winter though.
However, it sometimes occurs when going over bumps, or if the car is just going, if I put the rpms up a bit, there is a really bad rattle coming from the center of my dash. ANd I know its coming from there because when I hold down the center piece at the top of the dash, the rattling stops.
I'm going to bring it to the dealer and see if they could possibly tighten some screws or something.
I've got close to 3000 miles on my DE but no rattles. Try your best to find out exactly what is causing this and fix it. There was a lot of dash rattling in my impreza. The problem was the plastic clips, fixed it with some putty.
rattling noise
I got the same rattling noise in the dashboard(ES model). I've been able to pinpoint the problem. The round silver "rings" that go around the speedometer and rpm indicator rattle - in my car at around 2500rpm, and only when its cold.(and 5000 but I don't go there often...
). When you got the rattling sound try keeping those rings pushed against the dashboard and see if the rattling disappears. Hope this helps.
And just as a side note...I went to the dealership, I said "rattle,bumper to bumper,fix it" ... they said "go buy some glue, its not covered by the warranty". Oh well...they just lose me as a customer for the periodic inspections. Thats an easy fix after all...
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
I will have to try that. Thanks
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
I get a very annoying rattle in the dash, and have been un-able to find it so far.
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
I've got a rattle/vibration I can't really pinpoint too. I've never really thought it was the gauge casings, seems more central than that. Sometimes I think it's the change in the ashtray, but other times it seems like it's from somewhere else. I also got one that I pegged to B-pillar between the doors kinda between the seatbelt that really gets on my nerves because it's more frequent than the other one. I figure eventually I have to put some foam in there or something to deaden it, but I really don't know how I'd go about that. Anyone know how to get in there or have any ideas on fixing that for when the weather gets nicer?
Try and see if it is the housing around the air conditioning controls. I know that is a problem for me. Also I have rattles in my steering wheel housing like the plastic around the steering wheel. Check and see if that's it.
lol don't listen to krnkimchi702.... he is bitter he can't afford one... I know I am too! lol congrat by the way!
yea i have the rattling at about 2500 rpms... i pushed the stereo back and the sound stopped.. but my problem might be because i have a aftermarket kit so something might be loose, this is in cold weather too
Anyone have any resolution on the dash rattling issue? Mine rattles horribly the second I hit any minor crack in the road. Hard to describe, sounds almost like glass or aluminum rattling against something. Definitely sounds like the instrument gauges or inside the a/c vents. No clue how to even pull the dash apart, my old Scion tC came apart with ease, almost like LEGOs.
Oh -- and this all started happening maybe 1000 miles ago or thereabouts. Up to 22500 now.
If anyone needs any diagrams pm me, but they're not neccessary though.
Not sure if this is the same or not...
Iv been having this rattling/vibration coming from my dash. Commin home tonight i clicked off the air and the sound went away. I tried clickin back on the air to see if the sound came back, and it came back a little but not as loud. After that no matter what i did i couldn't tell, it could just be in my head to cuz im so used to that noise there.
my car had rattaling noises they came from the radio oem rockford so i pulled it out and noticed that the white oem clips where not tight enough so what i did is i pulled them off and where they clip i installed doubled side tape from 3m then i put the white clips on top of the 3mm and i reinstalled everything and the noises and rattalings went away.
