Grinding noise from left front wheel area
Old Apr 24, 2009, 09:58 AM
blaze_125's Avatar
Originally Posted by kronic420haze
the aftermarket bearing arnt sealed only the oem ones are is what my mechanic said
Looks kinda sealed to me.
And that's aftermarket. And that's what I bought, and that what it looked like when I received it too.
Old Apr 25, 2009, 03:32 AM
kronic420haze's Avatar
surely does there skipper
Old Apr 25, 2009, 06:40 AM
Rancidx's Avatar
the ones i was getting weren't sealed....
I just bought one this week and it was sealed like on the picture...
i'm hopeful, but then again, my first two bearings were replaced by the dealership by OEMs and that didn't change much....
Old Apr 27, 2009, 08:07 AM
blaze_125's Avatar
If they weren't sealed, they weren't oem.
But yeah, you live in Montreal... Roads are pretty sh!tty over there, there are god damn speed bump on highway 40 when you're coming from Ottawa. Are you ridding really sticky tires?
Old Apr 27, 2009, 10:09 AM
03_Lancer_ES's Avatar
If you have the stock open differential, only one wheel should spin when the tires are off the ground. You need an LSD to have both spin, otherwise the power goes via the path of least resistance. That does not indicate a problem with your differential at all.
Old Apr 27, 2009, 04:39 PM
mcgarvey's Avatar
Every wheel bearing made for this car, OEM or aftermarket, front or rear, is a sealed bearing assembly.
Old Apr 28, 2009, 07:44 AM
Rancidx's Avatar
nope...not every single one...
Old Apr 28, 2009, 07:46 AM
Rancidx's Avatar
when i say the first two, it's beacause so far i've gone through about 6-7....i lost count by now...
so the first 2 were oem.... then other ones weren't.... the only difference it made was that the OEMs lasted a year, while the non-oem's lasted between 6-10 months...
Old Apr 28, 2009, 07:49 AM
Rancidx's Avatar
what got me worried was that the right wheel was offering MUCH more resistance... which in the end was probably due to the defective wheel bearing...
Old Apr 28, 2009, 08:52 AM
blaze_125's Avatar
Were they all installed by the same shop?
If the same garage did the job every time, I'd change place. 1 wheel bearing a year isn't normal. You ain't drivin a Jimmy or a Blazer, you're driving a Lancer.
Old Apr 28, 2009, 09:07 AM
Rancidx's Avatar
2 dealerships and 3 or 4 different shops
i stick to the current one since he specializes in suspensions, i love his way of working (organized, experienced, efficient), charges cheap and he is honest...
none of that "the bearing is seized, i'll have to charge you 2 hours extra" bull****
i get to watch him work and no 16 year old high school dropout apprentice is touching my car - unlike most other garages/dealerships i've been to....
Old May 2, 2009, 01:02 PM
Rancidx's Avatar
Here is a pic of my latest failed bearing...
Clicky here
As you can see it's far from being sealed!
Old May 4, 2009, 04:55 AM
blaze_125's Avatar
I went on the Koyo website but couldn't search the part number.
Anyhow... wrong part being installed will lead to premature failure. The part could be Lancer branded but it's obviously not the design Mitsubishi recomands. When you get your next one installed, specify you want SKF bearings, or OEM.
kaarlwallace
Jun 12, 2013 02:51 AM
andify
Nov 21, 2009 07:37 PM
sti_killa
Sep 2, 2008 06:15 AM
ajutine
Feb 11, 2007 08:51 AM
deuxforever13
Apr 18, 2004 05:49 PM
Quick Reply: Grinding noise from left front wheel area
