tranny trouble
tranny trouble
I recently had my tranny replaced and they put my stage 2 clutch back in cuz i only have 20,000 miles on it. daily driving is mint. my problem is that when i try to go ***** out the clutch slips and the engine starts revving. is the clutch shot? is there a different solution other than replacing the clutch?
Have you checked brake fluid? Have you checked the clutch line hose?
Do you have a lightened flywheel? did you change the bearing also?
There could be a possibility of a lot of stuff so im not sure unless i actually tested out your car
PinnacleChronos
Jun 11, 2004 03:39 PM
