Rear Mud Flaps Install Question...
Just got rear mud flaps... It doesn't come with instructions so just wanted to double check on the install...
Each mud flap has 4 holes. It comes with 2 screws and 2 plastic fasteners. I'm assumming the screws go on the side mounts for the mud flaps? And the 2 plastic fasteners are used in the bottom holes on the mud flaps?
Hope that makes sense!
Thanks!
Thanks!
I believe the two plastic inserts go along the edge of the fender, while the screws go along the bottom to attach it to the bumper. I installed the evo x mudflaps, so its a little different on mine.
Should've gotten Rallyarmor. They look and work so much better. Plus they were dirt easy to install, didn't even have to take off my wheels.
If they're anything like the Rallyarmor's, you need to take the plugs out and put the threaded inserts behind the holes.
Finally found instructions... Screws go on the sides/top of the mud flaps... The clips are used to attach the bottom... Requires drilling one hole. Very straightforward install.
Molded front flaps are also now available for the GTS (OEM Mitsu). Part # MZ314116.
Thanks everyone!
Thanks everyone!
RallySport Direct
Evo X How Tos / Installations
18
Feb 19, 2015 08:31 PM
Z1 Performance
Oct 14, 2008 03:27 PM
2009, armor, de, evo, evolution, evolutionm, flaps, gts, guards, install, installation, installing, lancer, mud, rally
