A/C vibrations and Warm
Old Sep 22, 2009 | 07:21 AM
Lunchb0x's Avatar
Well its been a few since I've been on the board but i have been having some pretty terrible luck with my A/C lately. It seems as though its been downhill for a while but being summer still in South Florida its just becoming rediculous.
As of lately i have been having the following issues.
1. When loads are being put on the car, such as subwoofers, the Air conditioning seems to cut out. Now when i say "cut out" i mean, the air blows, all the a/c lights stay on but i just get air out of the vents.
2. When i idle with the air on, i seem to have a vibrating sound. From the outside of the car its very subtle, but from inside its the sound of metal vibrating against metal. Sounds like its around the firewall but i'm not sure as to what it could be.
3. As of this past weekend i ran into the biggest problem i have had yet. It seems that i can get the a/c to start out cold when i turn it on, but after a 4 to 5 minute drive, the air stops blowing cold and just blows. I havent noticed a difference between it cutting out when i come to traffic lights or while crusing down the street. It seems to be everywhere i go.
I can shut the a/c off for a few minutes, typically 10, and when i turn it back on, it seems to work for a few minutes, and again stops blowing cold.
I have had the lines vacuumed out and had new freon put in. I checked the level this morning and it is still full. Of all the things on the car, the A/C is the only thing i can do nothing about without some help. So any would be appreciative. Thank you all in advance.
BTW Todays HIGH for South Florida will be 90 degrees.
thanks!
Old Sep 23, 2009 | 12:11 PM
Lunchb0x's Avatar
bump
Old Sep 23, 2009 | 12:17 PM
Lunchb0x's Avatar
In addition, i can feel the compressor coming on and off in the pedal and in the acceleration. What i mean is, when cruising say at 50mph i can feel the car accelerating and slowing down on and off while the a/c is on.
Old Jul 12, 2011 | 08:11 PM
prezdead's Avatar
So I know this is a shot in the dark ....
Did you ever get an answer to your question Lunchb0x? Sounds like I'm dealing with the same issue.
Sorry for bumping a 2 year old thread :P
Old Jul 12, 2011 | 08:24 PM
Cal City Evo's Avatar
There is not a lot a it can be.
How do you know it's full OP? You need to look at the sight glass when it's warm with the A/C on high. If you see a lot of bubbles it is most likely a bit low. If you only get minimal bubbles your compressor switch could be going bad.
Is the clutch engaging when it calls for it? Another words is the inner part spinning when cold air is being called for? If not your compressor is shot.
The way to know for sure is put a manifold set on it and see what it tells you. If you don't know what you are doing take it to a shop and get it taken care of. It's not tough if you have the correct tools to do so.
Old Jul 12, 2011 | 09:54 PM
prezdead's Avatar
Had bubbles before charging it - now it's 100% clear.
When it acts up my fan cycles on and off every 5-10 seconds as my engine chokes out (rpms drop from ~900 @ idle to ~400rpm and it almost wants to die).
I'm almost positive it's the compressor (not what I want to hear though).
soderdna
Jul 19, 2015 10:29 AM
seiya
Lancer Engine Management / Tuning Forums
Jul 26, 2012 10:43 AM
kRAKA_P
Jul 12, 2012 06:21 AM
GST Racer
Apr 30, 2009 04:41 PM
fkw958
Feb 6, 2008 12:09 PM
Quick Reply: A/C vibrations and Warm
