2003 Mitsubishi Lancer A/T Fluid Pan Torque Specs?
Hey guys, I'm pulling my a/t fluid pan tomorrow because i've gotten my dipstick caught on something and I'm afraid to start my car now...
anyways, I need to know the torque specs and also if there is a pattern the bolts on the pan need to be torqued down to?
Thanks in advance.
Thanks in advance.
The valve body cover bolts get tightened down to 95 +/- 9 in-lbs. There is no tightening order. Just install them in an alternating pattern back and forth. Don't forget the bead of RTV to see the cover. You should be able to remove the cover and unhook the stuck dipstick. See the FSM diagram below.
420a-t
20
Jan 25, 2016 10:29 PM
Tiresomejunk
Dec 14, 2015 04:53 AM
