Hellppp!! Rusted and stripped bolts
Hey guys i am having problems with some rusted bolts. I was replacing my o2 sensor and i ot the car jaked up and looked under the car to see the bolt was completely stripped and rusted. So i decided to take off the cat to have more room. When i went to take off the cat i see those bolts were rusted as well. Any suggestions to get off rusted and or stripped bolts?? I have been sugested Pb blaster but i wanted a second opinion.
Thanks guys!!
Thanks guys!!
1 Post
Thanks guys!!
Thanks guys!!
Heat, use heat. Get a MAPP Gas torch and use that to heat the parts up. The heat will cause everything to expand and it will make life a lot easier to remove the bolts.
Another thing to try is an impact gun (or breaker bar) with impact sockets. The impact sockets are a hardened material and do have as much give in them as normal sockets and that will allow you to use extra force on the bolts (even if you don't use an impact gun).
-Bink
What binky suggested works. I had the same problems when installing the greddy exhaust, the bolts were all rusted. I used a breaker bar and pb blaster and it worked perfectly.
I recently installed my catback and even with PB blaster (used 3 days before install. sprayed it once each day and hours before install) I had a hell of a time breaking the bolts free. My brother used his foot with a extended socket wrench. A breaker bar would definitely help if you can get it under there. You'll need a 19 mm socket
Good Luck!!
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
Thanks all of you guys that helped alot.
I just sprayed the bolt with PB Blaster and am currently waiting now.
i used a breaker bar to get the other 3 bolts free but this last one is being stubborn haha.
