2009 GTS engine noise around 3000rpm
Old Sep 29, 2015, 01:04 PM
CamShaft's Avatar
Originally Posted by mwsmith69
I have the same noise as described above in a 2010 Mitsubishi Lancer 2.4L 5-speed (approx. 88000 miles). It lasts about 2 seconds upon start up and I hear it at about 2500-3000 RPM while driving/shifting. Took it to mechanic who replaced the timing chain, tensioner, and water pump. Took for test drive and no change in noise. Wondering is someone that has had same issue has found resolution to the problem.
Read the above posts and you may find an easy fix to your problem.
GTSGREY
Lancer Engine Tech
May 23, 2024 06:13 PM
jxp90
Mar 23, 2017 01:25 PM
eddy5201314
Jan 8, 2017 10:12 PM
Dimonstva
Lancer Tranny/Drivetrain Tech
Mar 23, 2016 10:40 AM
EVL4B11MR
Jan 22, 2016 05:03 AM
Quick Reply: 2009 GTS engine noise around 3000rpm
