lancer sidemarker replacement
can anyone tell me how to replace the bulbs in a sidemarker for a new lancer? Also, how to replace the amber bulbs in the headlight? do you have to remove the headlight? if so, is it just the 3 screws that are visible under the hood? also, is there any kind of repair manual like chiltons out there?
all you have to do for the side marker lights is get a screw driver with a cloth, and pop off the side marker, its as simple as that. for the headlights you just twist and pull out the bulbs. it's easy, takes a little finesse for the driver's side headlight because its tight, but its not that hard. don't you have a manual?
Well, i want to replace the amber bulbs in the headlights, and the one in the circle lens is easily accessable, but I cant seem to manage getting the one on the side by the fender. Thats why I was asking about taking the headlight out because its soo tight. I dont have a manual, I have an owners manual, but not like a chiltons repair manual. I cant seem to find one anywhere either.
Thanks
Thanks
the headlights have 3 screws.. you can plainly see them just take them out, and also unplug the wires and just be careful when pulling them out. and the bulbs just twist out very simple.
