O2 Sensor for 2002 lancer
Old May 15, 2013, 06:48 AM
Sairo's Avatar
Originally Posted by DVanDuzer
I replaced both. Front and Rear
Check your front exhaust pipe and the exhaust manifold. There might be some crack where air pass through.
When the code P0421 came to my car, I notice some exhaust air coming from the front exhaust pipe (pipe before the cat). I bought the exhaust pipe, installed it, and the code was gone. I just bought the O2 sensor due to the rebate and it somewhat improve the fuel consumption as well as the idle of the motor.
Old Jun 1, 2013, 09:56 PM
DVanDuzer's Avatar
Replaced the front cat (400$) and it took the code away.
Done with smog *yay*
Old Jun 2, 2013, 05:45 AM
eusgen's Avatar
So you had to replace the whole exhaust manifold? that is where the front cat is (right?)
Old Sep 15, 2013, 06:50 PM
luis argu's Avatar
I was able to fix the problem with the code P0421
the problem is q O2 sensor does not heat fast enough in my case was q exhaust manifold was not the original and the sensor is very low. place the sensor closer to the engine exhaust and ready
05-EVO-GSR
For Sale - Wheels / Tires
Jul 3, 2016 05:14 PM
saan2112
Lancer Engine Tech
14
Mar 28, 2016 12:10 PM
J2K10LANCER
Lancer Engine Tech
Mar 7, 2016 01:44 PM
Thahomeboyb
Lancer Troubleshooting
Feb 6, 2014 11:49 AM
blackdoutlancer
12
Jul 30, 2004 06:45 PM
Quick Reply: O2 Sensor for 2002 lancer
