Can someone please help troubleshoot brake issue
Have a 2009 lancer de cvt. A couple years ago, the left front brake worn down to 1/32, right front still at 50%. Had the pads replaced and again discovered the same thing. There was also a discrepancy between the outside and inside pads. Was told by a mechanic that the brakes will wear more on the left front if I come into a right turn braking hard than using the brakes when I'm doing a left turn. I also don't feel I'm getting good braking as compared to how it use to be at the beginning.
1. Is this air in the brake line?
2. Is is a defective caliper?
My car has 57000 miles on it and wonder if this would be covered by the warranty. I need to change brake pads right away, but fear that doing so, the dealership won't take me serious if I bring in the brake pads and show them the wear difference. Plus they may want to replace my brand new brake pads, if I get them replaced first, and put their own on. By the time they see their brake pads worn, my car would be past warranty.
My closest dealership is cerritos or Huntington beach. Which of these two would screw with me less?
Sounds like a caliper seizing up, you need to do both sides of the brakes, not just one. Any good mechanic will change both sides at the same time. You will need to either rebuild the caliper or clean and lube the slides. Get a good mechanic to look at it.
Three possible causes (and the mechanic you asked is an idiot BTW ):
1. Seizing caliper slider pin on the left front (clean and lube if posible - it should slide easily)
2. Failed brake hose to the front right caliper (a weak spot will 'bubble' with the rubber expanding (instead of transmitting all the brake pressure to the caliper).
3. Air in the front right brake.
Did the brakes 'pull' to one side?
Was the front left brake caliper much hotter than the right one after driving/stopping?
Do the brakes 'pulse' or shudder when stopping hard (indicates wapred rotor which indicates a seized/dragging brake)?
Pads are not covered under warranty.
Will the dealership cover the 1,2,3 above?
What would cause a stuck pin?
Yes it pulls to the left even after an alignment.. I didn't check for a temperature difference. The brakes started making a grinding rumbling noise when I stepped hard on the brakes a few days ago. Have beenn carefulto use brakes minimally since finding out there almost all gone.
What would cause a stuck pin? Dirt. There are bolts holding your caliper to your brake assembly. These bolts/pins are greased (and covered with a boot) so that they slide easily when you apply the brake, and release when you do the same. If dirt gets inside the boot (or if boot is torn), then you won't have grease to make everything run smoothly, creating shuddering brakes, pulling when braking, etc.
PDX_Nick
10
Sep 12, 2013 01:19 PM
A Furr
May 21, 2013 09:53 PM
Ignition Ready
Evo 'For Sale' Suspension / Brakes / Handling
22
Sep 3, 2012 03:06 PM
