front bumper
Old Aug 25, 2002 | 02:31 AM
gabrielg's Avatar
front bumper
Does anyone know how to take off the plastic grill located at the bottom of the front bumper?
Old Aug 25, 2002 | 02:41 AM
david02's Avatar
i think you have to take the front bumper off to reach all the retaining screws
Old Aug 25, 2002 | 03:02 AM
Metalak's Avatar
You dont HAVE to take the front bumper off to get to them. It is easier to get the grill out if you remove the bumper but personally I though removing the bumper was a complete pain in the ***. To remove the grills in the bumper make sure you have a stubby philips screw driver. Then remove both headlights. Next remove the 5 pop pins holding the black plastic guards on the underbody of the car. This makes it so you can move the upright black plastic guards underneath the headlights and remove grill screws more easily. Each of the small plastic grill pieces have 3 screws and come out relatively easily. The only screw I had problems with on the 2 small pieces was the one blocked by the wiper fluid resevoir. Now the center piece is a real pain in the ***. It is held in place by 2 screws and 6 slotted plastic tabs. Remove both of the screws from the center grate before popping the tabs. The screws are located one on the left side one on the right hidden inside deep plastic channels. The one on the drivers side is VERY difficult to remove due to an inconveniently place metal bar. If you are planning on putting something in place of the existing plastic grills you may want to call a friend buy some beer and take the bumper and its 50 million screws off. I took out my plastic grill pieces and replaced it with silver aluminum grill mesh it took 2 of us 2.5 hours to do it using the procedure described above. When we removed my bumper on a later project it took much much much longer.
Old Aug 26, 2002 | 10:32 AM
Barse's Avatar
You talking about the center or the two side pieces of grill? If it's the side pieces, just take off the splash guard under the car and you can get to the screws pretty easily.
doncarbone
Jul 29, 2017 03:47 PM
Simon Pugmire
Jan 15, 2017 12:42 AM
honda-guy
Sep 30, 2016 10:23 AM
sprx19
Aug 1, 2008 05:12 AM
Ink
12
Jul 25, 2006 07:59 AM
