Infinity sound system... mitsu cars in general
I was puting an after market radio into our outlander but it has the infinity sound system in it. As some of you may know because of the amplifier... there are no wires going from the speakers to the actual head unit. The wires simply run to the amplifier and a wire that looks almost like ones for CD changers run from the amp to the actual head unit. I was wondering if there's a wire for aftermarket headunits to plug into the amp wire.. so i don't have to run new wires from the speakers? So who out there has experience with the Infinity sound system? Replaced the factory to after market? Help a guy out! Thanx
This post may help you, it's all you need to know about the Infinity Sound System and aftermarket headunits:
https://www.evolutionm.net/forums/sh...et+adapter+amp
Even though you're talking about an Outlander, the Infinity system shares the same connectors on all Mitsu models (AFAIK). At least my Eclipse GT and now my EVO 8 SSL use the same adapters.
I hope it helps.
I hope it helps.
i recently installed an aftermarket HU in my evo wtih SSL. i had to buy the metra adapter and mitah adapter. however, i can't seem to adjust my sub at all. i can't turn it off or turn it up. did i hook up something wrong? the DIN to RCA adapter had 2 sets of RCA's but my new headunit has 3 sets (front, rear, sub). i believe my friend hooked up the front and rear, leaving the sub alone. was this hooked up right? thanks guys.
