Miata gets more grunt....
Old May 11, 2006, 02:18 PM
1NastyEvo's Avatar
Nice! A friend of mine has a 91 with the greddy turbo kit on it. It's alright.
Old May 13, 2006, 10:56 PM
silverEVO8's Avatar
Dyno results...
OK, I went to the dyno (Dynodynamics) today even though the clutch is questionable... The car is not tuned, but still it gained and incredible 52% whp increase from before the JRSC . There is definite room for improvement. The AF ratios are too lean until around 3500 rpm at 8 psi and too fat at 5300 rpm where the boost drops off for some reason... I think we can play with the static timing a little bit and pull it under boost as well as evening out the fuel curve. With a SAFC2, there might actually be another 5~15 whp to be had...
Oh yeah, at under 2200 lbs this puppy has a very nice power to weight ratio! I'm actiually better than a stock WRX ... Too bad I only have one wheel drive
Old May 18, 2006, 05:19 PM
silverEVO8's Avatar
OK, got a new clutch in there yesterday. We went with a 1.8 flywheel and Exedy stage 1. It's avery nice little clutch. It drives almost like stock, not problems at all with off-on action. Today I got a decnt chirp in second gear .... Oh yeah, changed the look as well. I've put some chrome, vintage type side mirrors there. Had to make some adapter plates, good thing I can get my hands on aluminum, sand paper, drill, tap and a polishing drill adapter...
Attached Thumbnails Miata gets more grunt....-vintageroadster1.jpg   Miata gets more grunt....-mirror.jpg
aznchin07
33
Jan 20, 2012 03:44 PM
rcboosted
Apr 18, 2011 05:47 PM
ElectricBlueIX
57
Sep 14, 2008 09:37 PM
freakitgood
18
Jul 29, 2008 02:50 PM
bacalhau16
12
Sep 28, 2005 09:36 PM
Quick Reply: Miata gets more grunt....
